Sink tap not working
pollypoo2
Post by pollypoo2 » Thu Jun 28, 2018 6:05 pm
Hi All,
Hope someone can advise me where to get my 12v pump repaired.
The water tank fills under the passenger seat so need to put van on a ramp to get under and access the water pump and repair/replace it. Does anyone know where I can get this fixed near Chesterfield/Sheffield?
The water tank is full but tank gauge not working and when switch on pump at zig unit the fuse is blowing.
Thanks!!
Re: Sink tap not working
Post by g8dhe » Thu Jun 28, 2018 6:50 pm
Might be worth finding a Caravan / Motorhome dealer who does repairs locally perhaps or might be worth a call to BongoSpares who would also be local to you perhaps ?
Post by Bob » Thu Jun 28, 2018 7:05 pm
I tried to help with this exact problem a while back.
Of course I can't remember who the convertor was, but eventualy it had to go back to them and they said 4 hours to remove and replace the pump. :shock:
Might be worth checking the wiring before looking to dig out the pump?
pollypoo2
Post by pollypoo2 » Fri Jun 29, 2018 5:07 pm
Thank you for your replies - I'll try Bongo Spares and a call to the converter and see where I get :)
Lisputerpie
Post by Lisputerpie » Tue Feb 25, 2020 11:58 am
I've fixed it myself, I bought a new faucet, which has a pull-down sprayer and a special system of instalation, it works well and I think that was a good decision.
JulesMartin
Post by JulesMartin » Tue Feb 25, 2020 6:47 pm
Definitely agree with Bob, check the wiring right through before embarking on retrieving the . more likely for a wire to have got chaffed or broken along the way than a submerged pump to come to grief.
Martin
