Just noticed this yesterday, the fuel guage was still reading with the keys removed from the ignition. I only noticed it because I was using a battery charger because the battery was flat. Don't know if the charger caused the needle to rise while I was charging the battery.
Any ideas?
Fuel gauge
Mikey B
pippin
Mikey B
fuel guage
If on permanently, would this cause the battery to drain? Just wondering incase I need to get a new battery, as I didn't use the Bongo from Saturday afternoon until monday morning, when I did flat battery.pippin wrote:There has been discussion on this before and the consensus was that the fuel gauge/guage for some odd reason does continue to read for a very long time (if not permanently) after the ignition is turned off. Weird/wierd.
pippin
Veg_Ian
Glynanderson
Kentish Paul
Mickey B: Just to confirm that the fuel guage is displaying the level all the time and uses no electrical power. And yes, after filling up it can take a full five minutes to confirm that you did not just half fill the tank.
I have found my Bongo's battery very resilient. In the winter, I often do not use the Bongo for more than a month at a time. On the coldest morning it fires up clan as a whistle. Earlier this year, I was told by a neighbour that I had gone on holiday with one of the interior lights switched on (two weeks). No problem.
So I think you may have to look elsewhere for what is draining the battery. Lots of threads on that here.
Bongo National Party - The law-abiding should have rights too!
