Can anyone direct me to where I can order 12mm replacement nuts for the exhaust manifold system. I’m in Canada and the Mazda dealerships don’t seem to have them here, so if anyone knows somewhere online I can order that would be so helpful!
Thanks again friends,
Jordan
Looking for replacement nuts
Bonneville
Re: Looking for replacement nuts
I'm not near mine to check but generally, a Japanese 12mm nut is an M8 but I can't confirm the pitch. You need both or risk something like this:
https://www.ebay.co.uk/itm/M8-x-1-25-me ... 2350127594
Generally any self-lock (but not Nyloc due to the heat) M8 x 1.25 should work unless it's Japanese fine pitch but without taking one off I can't confirm.
You should be able to obtain these nuts from your from your local Mazda /Ford dealer.... this is the part number.
http://www.vospers.com/parts/genuine-ma ... 2-5td.html
https://www.jimellismazdaparts.com/prod ... 00801.html
