few bits needed for Freda
If you are a private individual and are breaking a Bongo for parts, post brief details here. Once posted, the thread will be locked and all correspondence must be by PM or email. You can request a moderator unlock the thread for you to post an update.
NO TRADE! Trade ads must be placed on the main website 'For Sale' page https://igmaynard.co.uk/for-sale/
Moderator: francophile1947
Russell Jupp
Post by Russell Jupp » Tue Dec 18, 2018 3:42 pm
Hi all, after a few bits for 1995 Freda:
1. engine undertray
2. drivers' door window switch
3. Far rear, n/s cubby hole pocket.
Thanks,
Russ
The key to life: Fast bikes, fast cars, fast women. And a Bongo.
Re: few bits needed for Freda
Post by Bob » Tue Dec 18, 2018 4:24 pm
Bongo Spares are always a good shout if you can't find a private seller. :wink:
Tony x
Post by Tony x » Sat Dec 22, 2018 11:00 pm
Drivers door switch is common to the Mazda 323f 1998 era.
Post by mikeonb4c » Sun Dec 23, 2018 11:22 am
Tony x wrote: Sat Dec 22, 2018 11:00 pm Drivers door switch is common to the Mazda 323f 1998 era.
I'm curious about that myself as mines getting tired. Rather than a v expensive new Bongo unit, has anyone tried using one of these inside the original Bongo casing?
https://rover.ebay.com/rover/0/0/0?mpre ... 2626948786
Post by g8dhe » Sun Dec 23, 2018 4:43 pm
Some of the door switches have the drivers/passenger window switches reversed on the other models, so auto open/close and position is different.
Post by Bob » Sun Dec 23, 2018 7:32 pm
Thanks Mike and Geoff.
If the auto function being reversed id the only problem I could live woth that for the price. :wink:
Good info as always. :)
Post by g8dhe » Sun Dec 23, 2018 9:10 pm
Yup its possible to switch the wires over in the plug to correct the situation .
Post by mikeonb4c » Sun Dec 23, 2018 10:52 pm
g8dhe wrote: Sun Dec 23, 2018 4:43 pm Some of the door switches have the drivers/passenger window switches reversed on the other models, so auto open/close and position is different.
Thanks Geoff. I'm not much of a wife.....errrr.....wire swapper so just to be clear, are you saying the autoclose button will still control the drivers window in the unit as supplied. If not, is it relatively simple for a numpty with a soldering iron to wire swap?
Post by g8dhe » Mon Dec 24, 2018 10:43 am
The switches are in the same physical position, but they control the wrong window, so switch nearest the drivers window which has the auto function operates the passenger window, the switch closest to the driver operates the drivers window and has to be held open/close for full period of operation.
Post by mikeonb4c » Mon Dec 24, 2018 11:47 am
g8dhe wrote: Mon Dec 24, 2018 10:43 am The switches are in the same physical position, but they control the wrong window, so switch nearest the drivers window which has the auto function operates the passenger window, the switch closest to the driver operates the drivers window and has to be held open/close for full period of operation.
Thanks Geoff, clears that up. Would you say its a simple job to swap the wires over in the plug?
Post by g8dhe » Mon Dec 24, 2018 12:12 pm
Yes its just poke a small pin up to release the 4 connectors involved and swap them round as pairs;
The O - Orange for G- Green and
R/L - Red/Blue for R/W - Red/White
Post by mikeonb4c » Mon Dec 24, 2018 9:45 pm
g8dhe wrote: Mon Dec 24, 2018 12:12 pm Yes its just poke a small pin up to release the 4 connectors involved and swap them round as pairs;
Thanks+++ Geoff, a wonderful tip and i'm prompted to give it a go. :-)
Post by mikeonb4c » Wed Dec 26, 2018 5:59 pm
I enquired with the vendor of the cheap ebay one about the autoclose thing plus if it would fit the Bongo casing. They confirmed it would so at that price I ordered one as I'll be curious to see how it goes. Probably won't fit it until warmer weather but will try and remember to update on how it goes when i do.
This Bongo is costing me a fortune :lol:
Post by mikeonb4c » Sun Mar 10, 2019 12:20 pm
mikeonb4c wrote: Wed Dec 26, 2018 5:59 pm I enquired with the vendor of the cheap ebay one about the autoclose thing plus if it would fit the Bongo casing. They confirmed it would so at that price I ordered one as I'll be curious to see how it goes. Probably won't fit it until warmer weather but will try and remember to update on how it goes when i do.
Just to follow this up I fitted the item i bought and it took 20 mins to do the job and it works perfectly. V happy with that :-)
Merlot man
Post by Merlot man » Mon Mar 25, 2019 6:13 pm
mikeonb4c wrote: Sun Mar 10, 2019 12:20 pm
That's great to hear Mike , did you have to swap the wires around In the end ?
Brian
Return to “Breaking Bongos”
