Water in passenger side door well
mre3333
Post by mre3333 » Thu Feb 07, 2019 9:51 am
Hi guys, the rain from the past few days has managed to get into my passengar side door well. (See photo)
https://1drv.ms/u/s!As8mzMk7VnPaxWn4UGvBUkqZ8qxk
The street I am parked is on a bit of a camber with this side being higher I'm not sure if this is worsening the situation.
Any idea of what to check or usual suspects for leaks?
Rich
Re: Water in passenger side door well
Post by Doone » Thu Feb 07, 2019 2:42 pm
Here are 2 posts that may help; if you read through them there are various suggestions in the answers. :)
viewtopic.php?f=3&t=70379
And viewtopic.php?f=3&t=18510&p
mre3333
Post by mre3333 » Sat Feb 09, 2019 4:56 pm
Thanks for the hints.
I have taken the door panel off today and found the problem. I park on a slant so the door with the leak is higer than the other. Water comes in from bad seals and follows the front window runner down inside the door. Because of the parked angle all this water runs onto the speaker. The speaker only has a foam seal so once saturated escapes into the cabin.
I think it's just a design flaw.
Rich
mre3333
Post by mre3333 » Sat Feb 09, 2019 7:07 pm
Update... it is also leaking out of the hole in the panel for the door trim clip beneath and just to the left of the speaker. I'm wondering if I should try and try and shield the holes for speaker and clip or replace the rubber window seals and hopefully stop the water coming in the first place.
Does anyone know what sort of seal these electric windows take?
Thanks for all your help
Rich
Post by Bob » Sat Feb 09, 2019 7:57 pm
My guess would be replace the seal and stop water coming in.
Anything else is just treating the symptoms, not the disease. :wink:
mre3333
Post by mre3333 » Sat Feb 09, 2019 8:12 pm
Yeah that's what makes sense to me, do you know if I need to get a specific replacement part from say a breakers or something or are these things universal amd third party parts fit?
Sorry for my ignorance.
Rich
Tony x
Post by Tony x » Sat Feb 09, 2019 8:29 pm
I did read of someone replacing both door seals a while back. Seam to remember they were expensive but the owner was very pleased with the lack of wind noise.
I don't think you can buy a universal seal.
Post by teenmal » Sat Feb 09, 2019 10:31 pm
You can buy universal rubber seals, the problem is the shape / profile ,your local scrappie or coach builders/body shop is your bet.
But you might be able to do the oracle with some of these?
https://www.amazon.co.uk/s/?ie=UTF8&key ... 6722539088
Also on Ebay
Take care
