[img]https://flic.kr/p/2gnL3kf/img]
The wire had come loose from what the lush diagrams tell me is a magnet valve, on the rear of the diesel pump. Not very accessible, but I gently prised the rubber boot off and put an 8mm spanner on the top nut. A small crack was heard. The hollow nut underneath is filled with some rubbery stuff. Does anyone know what to do?
Magnetic valve on the diesel pump?
Distilled Waters Run Deep
Freda AFT: Haydn/Mason alarms + engine head temperature sensor.
Moto Guzzi California Jackal X reg
Re: Magnetic valve on the diesel pump?
Cant see image,but it sounds like you need a Stop Solenoid.
https://www.ebay.co.uk/itm/Mazda-Bongo- ... SwCPxc5SgU
Cheers, yes that's what it looks like. I wonder if I can put a smear of silicone in the recess and glue it back on with some epoxy - it seems that is what it was like before.
Has to be worth a try at the price of a new one!
Sorry it is not advisable to Try and repair these units,its a Stop solenoid and will do exactly that if a good contact is not made.You could be endangering yourself and others for the sake of a few quid.
Take extra care.
Take extra care.
Fair enough - but I'm afraid the last person who repaired it allowed epoxy to gather around the hex at the base, I must have put about 50lb/ft of pressure on it and it doesn't budge... Another repair attempt may be my best option!
Update on this, I found advice to soak the resin in methylated spirits overnight. Whether this helped, or I found extra grunt due to Teenmal's warning, I don't know, but I got the valve out.
The best part of £50 for a replacement when a very similar item for a Landover comes in at less than £8 baulks me though. I've wondered about fitting an inline solenoid before the pump - e.g. https://www.valtek.it/en/products/valves/type-06...
