Urgent Help - Fuel Pump Seal replacement
WestyK
Post by WestyK » Sun Sep 01, 2019 4:18 pm
Hi All.
Have a slight problem with replacing the fuel pump seals
All went quite well considering but when i started to tidy up found a small cup shaped washer that I can only assume came out of the spring side of the pump as this was the last side i did.
Easy enough to get at and it fits the in the plunger hole so am sure its from there.
My question is which way around dose it go I cant find a diagram that shows it.
Its not from the spring to cap side as I was very careful with this and it all came out together.
Thanks in advance.
Re: Urgent Help - Fuel Pump Seal replacement
Post by g8dhe » Sun Sep 01, 2019 7:24 pm
Do any of these images help ? Click the preview for full size image http://www.g8dhe.net/bongo_images/bosch_diesel_pump/
WestyK
Post by WestyK » Sun Sep 01, 2019 9:39 pm
Thank you
Yes that helps though I seem to have something in between the 2 types of pump.
The pump that looks like mine doesn't show this washer but the other one does. Odd :?
It shows it in the way i thought it went as well so am a little happier now.
I took a chance and fitted it how it seemed most logical to go and everything seems to be running fine (and no leaks) :)
For future reference the cup faces in side the pump / plunger so the flat side is against the spring.
Hope that may help others
