I'm fitting an lca (low coolant Alarm)
Having read up it has been suggested that i take an ignition switched live feed from fuse 7 (window blinds) straightforward...but!
I intend to fit a swap loom fed from a vsr/split charge system and 2nd battery which would then have a permanent live feed to the window blinds.
Any ideas/suggestions?
Lca fitting query
Timandclaire
- Bongonaut
- haydn callow
Re: Lca fitting query
Yep, take the feed from another switched live on that side of the fuse box.
