1999 2.5 v6 petrol
Power steering hose needed can you still buy then new.
The hose from the top of my power steering pump that has the bango joint on and connects to a metal pipe has sprung a few beautiful fountain like leaks when on full lock so needs replacing hence the above question as I'm not sure weather a secondhand one would be a good idea.
Any thoughts welcome.
Can you still buy power steering hoses new.
Bongobrain
- Apprentice Bongonaut
Re: Can you still buy power steering hoses new.
You could try this is the part number S09C3249XC I have fitted a few unobtainable new hoses , if you check you should be able to locate a Hydraulics company. Normally you would take the damaged hose a they will make up a new one , some firms do a mobile service.
This looks handy.
https://www.ebay.co.uk/itm/POWER-STEERI ... SwyKJfGreS
This looks handy.
Wonder if you could do a temporary repair with something like this:
https://www.toolstation.com/self-amalga ... ape/p55262
or this:
https://www.rustoleum.com/product-catal ... -Seal-Tape
Might help until you can get a replacement pipe.
or this:
Never run out of road, traction and ideas at the same time.
Bongobrain
Thanks to you all for the wonderful advice I will look for a local company to make a replacement hose.
