Mazda 3 wheels suitability?
Telsown
Post by Telsown » Wed Mar 03, 2021 5:00 pm
Hi all,
I am considering fitting a set of Mazda 3 17inch alloy wheels to my beloved 1997 Bongo friendee 4x4 diesel.
I have done the preliminary checks, eg centre bore 67.1 and bolt hole centres 114.3.
A couple of unanswered questions are:
What bolts do I use to fasten them to the hub and are they up to the job, weight wise assuming the correct tyres are used.
Thanks for any help/advice you can give
Re: Mazda 3 wheels suitability?
Post by Bob » Thu Mar 04, 2021 12:41 am
Given the Bongo is a good bit heavier than the '3' I wouldn't think the alloys would be up to it.
I just can't see a manufacturer over specifying wheels by that much, but someone may know better.
Telsown
Post by Telsown » Thu Mar 04, 2021 10:40 am
I was fearing that would be the case. Would you bee up for recommending a competent company to supply me with the correct setup?
Post by Bob » Thu Mar 04, 2021 10:58 am
I'm not really up to date on alloy suppliers, I'm afraid.
Sorry I can't help with that. :(
Telsown
Post by Telsown » Thu Mar 04, 2021 11:20 am
How about fitting steels. Can you help with that.
To be honest, it was what I was after in the first place.
Maybe go up to 17's?
Post by Bob » Thu Mar 04, 2021 1:09 pm
Sorry, mine's on standard 15”.
Someone may have an idea, with luck.
cwilliams255
Post by cwilliams255 » Thu Mar 04, 2021 2:55 pm
The wheels on my 3 were all bent to some degree after a couple of years of potholes. Higher sidewalls would have helped but pretty sure they won’t be up to much on a bongo
On the subject of steels, some pretty good ideas on one of the Facebook groups
Telsown
Post by Telsown » Thu Mar 04, 2021 4:27 pm
Thanks to everyone for their input.
Not sure the solution is on this forum!
Post by Doone » Thu Mar 04, 2021 4:53 pm
You'll want wheels that will take the weight of the Bongo. BongoSpares often sell refurbished sets that will fit.
Post by Bob » Thu Mar 04, 2021 5:04 pm
Good thought. 8)
And Wheelquick, Wigan, used to fit alloys to all the Bongos they sold (which was a lot) so they would be able to source new.
