What I have tried/conditions: ‘95 Diesel auto. battery is brand new 335 type, fully charged. Terminals tight, battery earth to body clean and tight. All fuses appear ok. All external lights working. The 15a fuse that feeds the dash is good and there is 12v power there with ign on. I have 12v at the thicker of the two wires feeding the alternator but not on the thinner (ign on or off). I think this might be the exciter? Belts fine on alternator and tried jump lead to provide additional earth. Have looked over all obvious plugs/cables. I was working behind the radio around the time this started but don’t think I disturbed anything.
Any help suggestions appreciated. I have scoured the net and found a couple of reports of similar but no outcome solution. Cheers.
I suspect may be alternator (but no lights beforehand either) I will remove and get tested but wouldn’t expect faulty alternator to knock out most of the dash warning lights?
