Fiamma F35 Pro + VW T3 brackets - mushroom roof -any tips?
Posted: Thu Jun 30, 2022 1:15 pm
Hi. Hopefully this is my last post about Fiamma awnings...
Thanks to people on this site, I've worked out that my best option was a F35 awning with T3 brackets and the kit arrived today.
Offering the brackets up to the Bongo shows they are a pretty good fit, but maybe dont quite sit at the very bottom of the gutters, which I guess isnt ideal. Also, the front bracket either needs grinding down, or it has to overlap the sliding door slightly (which isnt an issue).
Any tips on fitting? I dont have the tools to grind the brackets, so I'm hoping this isnt necessary.
It looks like the plastic pad on the bottom of the front bracket might not make good contact with the van. I dont think bending the bracket is an option, so have people bent their gutter slightly, or padded out the space behind somehow? The rear bracket seems a good fit.
I've seen pictures of the brackets bolted through the body work of Bongos, which is something I might do after a test drive, if the awning moves around or flexes the gutter. Also a good anti-theft precaution.
