Problems with sliding doors. Need help
kevinhenry
Post by kevinhenry » Tue Jul 05, 2022 3:54 am
Hi, I'm having a problem with the sliding door closer. I have checked about fuses and electrical connections. Everything is fine but the sliding door stops working for unknown reasons.
Need help from you guys. Thank!
Re: Problems with sliding doors. Need help
Post by g8dhe » Tue Jul 05, 2022 8:16 am
Welcome aboard!
Have you tried cleaning the 5 connectors on the "B" pillar and the door itself, best to use a plastic kitchen sourer as they remain live to 12volts.
Its also worth checking that the alignment posts are in position and not significantly damaged there is one at the top of the "B" pillar and another I think lower down. They are simple black plastic covered projections bolted to the "B" pillar and make sure that the door is aligned with the "B" pillar.
