Cobra central locking
joeeynon
Post by joeeynon » Fri Jul 08, 2022 2:05 pm
My Bongo door locks would only turn in one direction and the central locking wouldn't operate. Inside the door I disconnected the rod from the door lock and found the key correctly turns the lock in both directions.
The rod appears to be prevented from travelling in one direction. With this rod disconnected the central locking now works correctly on all four doors. Can anyone explain what could be jamming this rod?
I’d like to get the locking working on the key in case the fob breaks.
Cheers everyone
Would rather be adventuring
Re: Cobra central locking
Post by g8dhe » Fri Jul 08, 2022 2:09 pm
Welcome aboard!
Have you looked at the mechanical diagrams ? http://www.lushprojects.com/bongopartsm ... mgno=.html this is the page for the front door mechanism.
joeeynon
Post by joeeynon » Fri Jul 08, 2022 5:28 pm
Yeah I’ve got the diagram already. When assembled as it should be the key doesn’t turn.
Post by g8dhe » Fri Jul 08, 2022 5:37 pm
Can you work out which of the rods is jamming it ? There is the inner door lever and the lock button they should be get at-able ?
joeeynon
Post by joeeynon » Sat Jul 09, 2022 7:52 pm
It’s the lever/rod from the key barrel which moves when you turn the key. That rod is fouling on the vertical rod. Nothing looks bent or damaged.
Post by g8dhe » Sat Jul 09, 2022 9:38 pm
Is the vertical rod the one to the solenoid that the Cobra key fob operates ? In which case it sounds like the solenoid has a problem perhaps ?
