Starter motor gen difference
Ebell12
Post by Ebell12 » Sat Sep 30, 2023 2:06 am
Good day all.
Ordered a replacement starter motor off eBay for my 99 diesel. Sadly it looks like I have a 99.5 as the starter motor in the vehicle looks slightly different and on lushprojects the part number is different.
The old one slides in place and looks like it would work. Bolt holes line up and such. Does anyone know if this is the case? I did not install it in time to be able to return it.
Thank you
Re: Starter motor gen difference
Post by g8dhe » Sat Sep 30, 2023 9:59 am
So the new (?) one looks like it would fit, does it have a reference number, quite often there are identical units made by different companies that have different part numbers. Also your not a "cold" start Northern Japan model are you as they did have a different starter motor but they still fit the same I believe.
Post by Bob » Sat Sep 30, 2023 12:47 pm
Often the starter can be fixed with a repair kit, available pretty cheap off Flea Bay.
Ebell12
Post by Ebell12 » Sat Sep 30, 2023 3:24 pm
Looking back I could have explained myself better. This is what the one I purchased looks like. Half of the gear is covered
https://www.ebay.ca/itm/185945156942?ha ... BMgv6R59xi
This is what the original looks like. Fully exposed gear.
https://www.ebay.ca/itm/291116148073?ha ... BMgv6R59xi
When test fitting it fits in just the same. Just not sure how it matches up internally with that gear half covered. Thanks for the replies!
Post by g8dhe » Sat Sep 30, 2023 3:32 pm
The half exposed type is a "cold" starter version (12v / 2.2Kw),
whilst the original is the normal style (12v / 2.0Kw);
Both types are listed here on the parts diagrams https://www.lushprojects.com/bongoparts ... Btr.html#6
Ebell12
Post by Ebell12 » Sat Sep 30, 2023 5:35 pm
Thank you! Great news as I am in a very cold climate.
