OVERHEATING HELP!!!!
amwamls
I recently had a cracked expansion tank which caused my bongo to leak and overheat.
I have replaced this but have had overheating problems since.
I've changed the thermostat.
Flushed the radiator.
bled the system.
At present it runs fine for 15 mins then the temperature keeps creeping right up and I have to stop.
The heaters are working fine but the radiator is still cold!!
My next move was going to be the waterpump, but I didn't think the heaters would work if this was faulty.
Any ideas?????
bled the system.
Any ideas?????
- dandywarhol
amwamls
Not loosing any water and I've downloaded the coolant section from the manual and followed it to the letter.
I've taken the bottom hose off the radiator and water flows freely through the rad.
I took the belts off the waterpump today and spun it, there was no resistance at all so I'm going to plump for that otherwise I'm all out of ideas.
reading through the forums on some of the head problems is giving me nightmares
flash
Bumbly1
Flushing the radiator is not enough, you are best to flush out the whole system as the gunge will still be lurking in resricted passageways and will creep out and block the rad again just when you are least expecting it.amwamls wrote:Not loosing any water and I've downloaded the coolant section from the manual and followed it to the letter.
- dandywarhol
Bumbly1
I have/had a manual and we downloaded the bit from members. It is possible just to buy the coolant bit of the manual from the publishers, the details are elsewhere. The Linlithgow guy is a keen and interested mechanic who does not bodge but he is not a Bongo expert - yet. The Bongo is not particulalrly complex when compared to many more modern vehicles, imho it only requires someone who is keen to get to the root of the problem and diagnose it properlyvanvliet wrote:Bumbly - Does the Linlithgow mechanic you mentioned previously have enough knowlege of Bongos to do this job? Does he have a manual?
Bumbly1
Re: rad
That is worth doing but it is only part of the problem, the gunge can, and does often still lurk elsewhere.antique wrote:hi to be safe take rad out and get it flow tested, new core £100 approx
