I have a question on electrics / leisure batteries.
Francophile has been of great help via a separate topic
I have also read the forum in depth.
However I have read something which I can't find now.
The Main battery connected to leisure battery via split charger relay. The Leisure Battery needs to be disconnected when the engine is turned off.
What system is there for disconnecting the leisure battery that doesn't require using spanners?
It is mentioned somewhere!
Also, if I park up, don't turn any electrical stuff on when engine is off, do I need to disconnect the leisure battery?
If I leave the leisure battery connected, how long could I leave the internal lights on before I risked running the main one flat? Or how long could I leave the radio on ? (assuming all is routed through the leisure battery).
Thankyou!
Spent the day searching info and pulling van apart.
Feel like I need to go and do this
