Exhaust Manifold stud replaced in garage
timhum
Post by timhum » Fri Feb 16, 2007 6:46 pm
I have put the Bongo into a local motor engineering works to deal with the No.1 manifold stud which has sheared.
I sourced the gaskets and new stud from AVA and it went in this morning to get the job done. This afternoon I get a call from the garage saying they have had a bad time removing the EGR pipe (in order to remove the turbo to get to the manifold). The outcome is that I shant have the Bongo back till Monday, who knows what else might be found once they get further into the job!
Am I getting waffle from the garage (about EGR removal pipe), or does that seem about right.
Waits with baited breath...
Thanks,
Tim
antique
stud
Post by antique » Fri Feb 16, 2007 7:52 pm
hi timhum dont forget its friday ?
Peg leg Pete
Post by Peg leg Pete » Fri Feb 16, 2007 8:26 pm
My local garage do a great job, but I never get it back the same day, they are so busy, lot of members are blocking the egr these days, tempted myself :wink:
Image Pete
Post by haydn callow » Fri Feb 16, 2007 8:50 pm
I drilled out and put a new bit of stud in the No1. Didn't remove anything except loosened the heat shield. Put a bit of metal sleeve in the manifold hole to help centre the drill (cobalt/carbide), drilled a 6mm hole first then 8mm, helicoil and then a bit of 8mm stud. Whole job took about 3 hours. Been lovely and quite now for 600 miles. You can get at this stud without removing loads of stuff, I think I also swung the alternator out of the way as I was replacing the belts anyway.
Post by haydn callow » Fri Feb 16, 2007 8:53 pm
P.S. If your gasket is US then I suppose they would have to remove the ERG. Mine was o.k. as it happened
aitch
Location: in a place far, far away, well Somerset for now!!!
Post by aitch » Fri Feb 16, 2007 9:55 pm
sorry to be a little thick but what does ERG stand for? thanks for replies in advance
Post by francophile1947 » Fri Feb 16, 2007 10:00 pm
Should be EGR (exhaust gas recycling) valve.
aitch
Post by aitch » Fri Feb 16, 2007 10:10 pm
Thanks for that I thought I might still have been looking at the acronyms postings in off messages and missed something.
