Got the dreaded passenger window problems! Seemed to be related to the isolator on the drivers door switch. If I pressed it hard the window would work.... so, remember reading on here that someone had bypassed this part of the switch. Have tried to find that thread again but no joy.
Thought I would do that last night, so took the switch off to have a look. Could not make out on the board where the contacts were going so thought I would unscrew the white backing to inspect closer!
I was left looking at small spring and ball bearing that appeared as if by magic giving me no clue whatsoever where it escaped from. The rocker now has no click to it
Anyone on here know where it sprung from... if you excuse the pun!
Adie
