cruise control
brianwfl
cruise control
Hi mrs d
enter howard mays cruise cotrol in the internet search, for all info on non vacuum cruise control. its a doddle to fit diy or steve jones can fit for you at your premises.
brgds brianwfl
brgds brianwfl
BarryS
ferdyb
Can I just query the fitting of a speed sensor circuit to the engine of a vehicle with auto transmission? Surely, until the lock-up occurs, all the other gears are only loosely related to the actual road speed via the torque converter? So the engine is never going to be a reliable indicator of road speed.
Come to think of it, even with a manual gearbox, the engine is only in direct, one to one contact with the propshaft, and hence road speed, in fourth gear as well.
ferdy
ferdy
Dave up north
ferdyb
Yes Dave, I agree with that, it's just that AliBongo in a post on the first page mentioned taking a feed off the coil, which would only give engine speed, which may or may not be related to road speed, especially with an auto box, I would have thought.
I admit I don't know much about it either, it all sounds far too dangerous and likely to send me off to sleep.
ferdy
ferdy
- dandywarhol
AliBongo
I got my vaccum from a pipe at the front of the engine just to the offside of the water pump. On my 1996 Bongo there is a metal pipe going straight up in front of the engine with a ready made vacuum take off with a blanking pug on it. If you shine a torch in from the passenger side you should see it.
