maxheadroom
Post
by maxheadroom » Thu Feb 11, 2010 8:36 pm
Cheers Ian head arrived today
just hope I can get some of it done the weekend, in between decorating and a friends daughters first birthday
Keep the Faith
Post
by mikeonb4c » Thu Feb 11, 2010 11:00 pm
maxheadroom wrote:Cheers Ian head arrived today
Good luck. If only I was younger and fitter, this sounds like quite an exciting challenge in its own way, especially with the reassurance of a complete kit from our Ian - a nice touch, as its the running around getting parts that always does my head in
Post
by Bob » Thu Feb 11, 2010 11:06 pm
Good luck, hope all goes well for you.
mister munkey
Post
by mister munkey » Thu Feb 11, 2010 11:17 pm
The one nasty thing I found when my head was replaced was the difference in shinyness between the block & the head.
I've spent over two years now trying to get them to match, poking holes in the rocker cover gasket seems to work alright.
dandywarhol
Post
by dandywarhol » Thu Feb 11, 2010 11:20 pm
Make sure there's moulded recesses in the cam cover bolt holes - otherwise you end up with oil leaks by overtightening it
Post
by mikeonb4c » Fri Feb 12, 2010 12:33 am
dandywarhol wrote:Make sure there's moulded recesses in the cam cover bolt holes - otherwise you end up with oil leaks by overtightening it
Good point - there's on old thread on here somewhere about that (rocker cover, if you can still call them that) isn't there?
helen&tony
Post
by helen&tony » Fri Feb 12, 2010 6:28 am
Yes...Best of Luck....I hope it doesn't take you too long!
Post
by Doone » Fri Feb 12, 2010 5:22 pm
Is it
THIS ONE?
dandywarhol
Post
by dandywarhol » Fri Feb 12, 2010 6:50 pm
Aye
maxheadroom
Post
by maxheadroom » Sat Feb 13, 2010 8:41 am
cheers chaps notes taken
Keep the Faith
maxheadroom
Post
by maxheadroom » Sun Mar 21, 2010 6:38 pm
Keep the Faith
mister munkey
Post
by mister munkey » Sun Mar 21, 2010 6:43 pm
maxheadroom
Post
by maxheadroom » Sun Mar 21, 2010 6:44 pm
mister munkey wrote: You need to get some of those missing miles under your belt now!!!
Oh yes
Keep the Faith
Post
by francophile1947 » Sun Mar 21, 2010 7:41 pm
mister munkey wrote:I wish I had one of those firework emoticon wotsits.
Like this
Well done Max
Post
by mikeonb4c » Sun Mar 21, 2010 7:42 pm
