Fuel sender cover and carpet
thedogsbollox
Post by thedogsbollox » Tue Mar 16, 2010 6:36 pm
Well i went to do the fuel sender wires today and started ripping out the carpet, till i reached the rails for the middle seats. It suddenly dawned on me that this is not as easy a job as i first thought.
Will i have to remove the side panels, trims, seats, belts, rail covers in order to do this. The reason i ask is two fold, firstly obviously to get at the fuel sender and secondly i will soon be embarking on some work that will require me to remove one or more of these panels anyway, maybe i should wait.
wonkanoby
Re: Fuel sender cover and carpet
Post by wonkanoby » Tue Mar 16, 2010 6:58 pm
no as carpets split as i recall and just slots around them
for sure never had to remove things to get it out
found a paint scraper handy to retuck under the sides though
Post by missfixit70 » Tue Mar 16, 2010 7:08 pm
Should get away with sliding the plastic covers back on the rails which should then allow the carpet to be lifted, but I think it'll be easier with the seats & that side panel out if you're going to have it out anyway in the near future.
thedogsbollox
Post by thedogsbollox » Tue Mar 16, 2010 7:10 pm
missfixit70 wrote:Should get away with sliding the plastic covers back on the rails which should then allow the carpet to be lifted, but I think it'll be easier with the seats & that side panel out if you're going to have it out anyway in the near future.
Ta, will wait till then
