diesel bongo query
- You've Been Bongod
diesel bongo query
my bongo battery light and headlights flicker every now and then have had battery and alternator checked by kwik fit and they say both ok
would this be a bad earth somewhere ?
Re: diesel bongo queerie
Personally I'd have it checked out by an expert who knows something about electrics.
- gmaczbongo
Re: diesel bongo query
If it is a flicker on tickover, It maybe just needs a slight increase in the tickover speed.
- dreamwarrioruk
id have another opinion on the alternator, has there been any other wires tapped into the alternator circuit.
mike, jo and emma
all wires intact
runs fine
starts fine even when parked up for 2 weeks without starting
alternator also looks like its fairly new
i wonder if they have caught a wire when fitting ?
runs fine
Is there a pattern to the flicker...? Like when hitting a speed bump/pothole?? Is this more likely to happen on a dry day?You've Been Bongod wrote:my bongo battery light and headlights flicker every now and then have had battery and alternator checked by kwik fit and they say both ok
jaylee
only patten is it happens when on tickover
Might be worth looking to see if it has one of those courtesy headlight dippers that maybe disabled, but on the blink?
- mister munkey
The cynical side of me would take the view that if KF were to supply Bongo alternators, they'd have flogged you one on the spot.You've Been Bongod wrote: have had battery and alternator checked by kwik fit and they say both ok
Sounds like worn brushes to me mate.
its now in the capable hands of the midlands / staffs/ shropshire bongo specialist
ian taylor
i will let you know the outcome
then she will be for sale as keeping the v6
ian taylor
