rocker arms
robbie c
rocker arms
Post by robbie c » Thu Apr 22, 2010 8:52 pm
4 of the rocker arms on my 2.5 diesel bongo are begining to wear, where can I get some new ones from ?
thanks
Rob
Re: rocker arms
Post by francophile1947 » Fri Apr 23, 2010 8:55 am
Welcome to the site :D
It would help if we knew where you were - see http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=29471
Have a look at the Home page here http://www.igmaynard.co.uk/bongo/bongo.htm - several dealers on there :D
dandywarhol
Re: rocker arms
Post by dandywarhol » Fri Apr 23, 2010 12:44 pm
Before you fit new ones - find out why the old ones wore and why only 4 of them..............
gmaczbongo
Re: rocker arms
Post by gmaczbongo » Fri Apr 23, 2010 7:15 pm
What do you mean by beginning to wear?
Need more info.
robbie c
Re: rocker arms
Post by robbie c » Sun Apr 25, 2010 6:54 pm
the van was purchased with the engine running very poorly.
had a look and its a bit more serious, the ball joints that the rockers sit in are badly worn. It looks as if the y are the wrong size thread. That however does not change the fact that unless I helicoil the head it will be scrap.
so a dilema, throw a "recon" engine in or sort this one out ?
