Northern Bongolow wrote:you say you have had the pads changed,did you have the brake fluid changed,or was the system bled, if so someone may have used a preasure bleed/fill system on it, maybe this has caused your issues???
Thanks NB, I am not sure what they did as I wasnt present at the time, but can this cause what Simon has suggested below?
Simon Jones wrote:This is quite a common fault on Volvo S60/V70 where the diaphragm starts to perish so the seal is no longer airtight. To change one of these costs over £500 as the engine has to be lowered to gain access to it. On a Bongo it would be a much simpler just & a decent used one can be picked up for under £60:
http://cgi.ebay.co.uk/MAZDA-BONGO-SERVO ... _500wt_956
Probably worth getting it back to the garage that did the work to see what they suggest.
Thanks Simon, its going back in tomorrow.
rita wrote:Hi,does it have a non-return valve on the servo??
Hi Rita, I am not sure if it does have a non return valve.
Thanks for all your suggestions
