I've fitted both the above today, very straight forward and pleased with both products.
However, as I've got the sockets and stereo running from the leisure battery now I'm unsure what ignition switched live I should use - any thoughts/tips?
Cheers!
Willinton & Hayden Alarm
- TechnoTurkey
Member 10,000!
1997 Green AFT 4x4 2.5TD Auto Bongo
- missfixit70
Re: Willington & Hayden Alarm
If you've fitted the willinton kit as per instructions, you'll have the ignition live connections spare in the top fuse connections, makes life easy
just make/buy a male connector to slot in there for the LCA.
- TechnoTurkey
Re: Willinton & Hayden Alarm
Good thinking - I'll try and fix it up this week.
Many thanks Kirsty!
Many thanks Kirsty!
Member 10,000!
