Willinton & Hayden Alarm
TechnoTurkey
Post by TechnoTurkey » Sun May 23, 2010 9:38 pm
I've fitted both the above today, very straight forward and pleased with both products.
However, as I've got the sockets and stereo running from the leisure battery now I'm unsure what ignition switched live I should use - any thoughts/tips?
Cheers!
Member 10,000!
1997 Green AFT 4x4 2.5TD Auto Bongo
Re: Willington & Hayden Alarm
Post by missfixit70 » Sun May 23, 2010 11:58 pm
If you've fitted the willinton kit as per instructions, you'll have the ignition live connections spare in the top fuse connections, makes life easy :wink: just make/buy a male connector to slot in there for the LCA.
TechnoTurkey
Re: Willinton & Hayden Alarm
Post by TechnoTurkey » Mon May 24, 2010 8:43 am
Good thinking - I'll try and fix it up this week.
Many thanks Kirsty!
Member 10,000!
