HELP! I have a leaky Bongo....
Hi All,
I've read through a few posts now but still unsure on where to start troubleshooting, When I fill up the water/coolamnt reservoir under the bonnet (Top right) after a minute the wate starts to drip from out under the alternator belt area, (The engine is not turned on at this point), I've had a good look round underneath, and the water appears to be running down the crankshaft area and behind the crankshaft pully, it then starts dripping over the edge......
http://i802.photobucket.com/albums/yy30 ... /leak3.jpg
http://i802.photobucket.com/albums/yy30 ... /leak2.jpg
http://i802.photobucket.com/albums/yy30 ... /leak1.jpg
Any help appreciated.....
1997 Mazda 2.5TD 4WD AFT (Current) - The Red Slipper!
1995 Mazda 2.5TD 2WD AFT (2007- 2014 RIP)
- maxheadroom
Re: HELP! I have a leaky Bongo....
Was wondering the same thing...? Had mine sorted a few weeks back. Showed signs of a leak when the engine was stopped!
- brorabongo
- mikexgough
I would have gone for water pump
- mister munkey
Most likely water pump.
Genuine ones from Club Shop @ £66, cheaper on ebay but be wary of cheap imitations . . . .
Hi conmai,
Water coming from that location,could be a faulty(leaking) core plug.
Thanks for the suggestions.....Water pump sounds like a good place to start first...Although I'm not familiar on the Core Plug?
Thanks for the thread link too, I'll post back when I find something more.
Ta
Ta
dandemann8
Hi, you need to put your location in your profile as there maybe another Fury member close by who can assist
Bongo no more........... ;-(
Thanks.....profile now updated, Bongo still on ramps, will have be having a look this afternoon..
Ta
Ta
