Towing a Bongo
BONGO191
Towing a Bongo
Read somewhere that 4x4 Bongos should not be towed does anyone know why not??
- missfixit70
Re: Towing a Bongo
Two main reasons as I understand it,
1 - auto gearbox will self destruct if it's towed as the oil won't be pumping around, kinda like running the engine with no oil pumping round
2- 4wd will "wind itself up" , you could tow it if you disconnect the front propshaft, but you'd still have the issue of it being an auto (unless yours is one of the rare manual ones)
Re: Towing a Bongo
And 'Alacrity' has given some info ON THIS LINK.
BONGO191
Re: Towing a Bongo
Thanks for this all makes sense when you hear the explanation.
