I have manual aircon controls and the green light comes on as usual when you press it and turn the blower control, but only warm air comes out.....
Hoping someone can help!
Steve
That was my worry....francophile1947 wrote:Sudden change like that is usually down to damage somewhere. Unfortunately, the aircon radiator is unprotected and may be damaged by stone chips
Don't know about Bongo system, but the aircon is usually less efficient for quite a while before the pressure drops enough to let the switch cut in. If he had a nice refuge in the hot weather, it doesn't sound as if it was inefficient at that timemissfixit70 wrote:Could it just be the gas has just leaked enough to drop below the pressure switch point? Has to be a cut off somewhere?
