engine wont turn off
flipflop
help !!!
my engine wont turn off have taken keys out
please need help
07899995480
please need help
07899995480
Sharkojoints
- Bongonaut
Re: engine wont turn off
Check the stop solenoid:
Nr 24-3002
Should activate with 12v across it. You could try giving it a tap of encouragement, or unscrew and operate manually!
eta That's a drawing of the diesel pump, living under the driver's seat, in case it's not clear!
Do a forum search for "stop solenoid" and all will become clear:
http://www.igmaynard.co.uk/bongo/forum/ ... mit=Search
Other methods of stopping engine:
1. Disconnect fuel pipe feed to fuel pump
2. Block air intake
I'd go for nr1 if I had to.
HTH
Nr 24-3002
2. Block air intake
HTH
mechanic on scheene now guys and girls
flipflop
who doesn't know what he is doing!!!!
- mikexgough
flipflop wrote:who doesn't know what he is doing!!!!
flipflop
The mechanic that is here!
mikexgough wrote:flipflop wrote:who doesn't know what he is doing!!!!
Double
Daz and debs
integraR
C02 fire extinguisher aimed at the intake should do it, if the turbos leaking oil then good luck but it prob would have gone bang by now if it was that.
wishmaster
- Tribal Elder
wormey wrote:mikexgough wrote:flipflop wrote:who doesn't know what he is doing!!!!
Double![]()
Izzy
flipflop
just a guy from my insurance company, don't think they usually come across bongos
- missfixit70
All he's got to do is disconnect the fuel line - or can't he find the engine
flipflop
tried everything on here and more and the bugger still wont turn off!!
Sharkojoints
- Bongonaut
Blimey - it even runs with the fuel line disconnected? I'd keep it quiet - you might be on to something big!flipflop wrote:tried everything on here and more and the bugger still wont turn off!!
I reckon you might win the mpg thread if you play your cards right...
- missfixit70
If it's got no fuel going to it, then it must be consuming the oil from the sump, you need to stop the air getting in, best way may be to go under the passy seat where the turbo is disconnect the plastic u bend on thr front of the turbo & block the air inlet to the intercooler/engine. If it's left to run it will go bang as it will have no lubrication, co2 extinguisher suggestion may be worth trying cos you want it stopped quick.
Either that or the mechanic ain't stopped the fuel going in?
flipflop
Thanks for all your help guys and girls, they have finally got it to stop by blocking the air intake!!
