Amazing Heater Motor Fix!
simon_gone_surfing
Post by simon_gone_surfing » Sat Aug 14, 2010 8:46 pm
I have posted in the past looking for fixes to my ongoing (4 year!) heater motor problems, with no solutions found. In a nutshell, I only got the slightest breath of air through the vents. Solutions tried (and failed): i) speed control resistor resoldered (twice); ii) motor stripped down, cleaned, greased and refitted (twice); iii) new motor fitted...but then...a breakthrough...
I now have wind at all four speeds (no bean jokes please) and it's like an arctic wind tunnel! How did I achieve this feat? (This is where I look like a right idiot)... while the blower system was stripped down again last week I noticed the mini radiator which supplies heat to the blowers was a bit dirty looking, so I gave it a rub with a toothbrush...there was more cr*p clogged in the radiator fins than in my wife's hairdryer. 20mins of gentle (the radiator fins are quite easy to bend it turns out) brushing and hoovering removed most of the crud and it now works perfectly!
The moral - if it ain't working, it aint' necessarily broke and might not need fixing, it might just need a good clean!
Please can any other limp-wind bongonauts try this and let me know it's not just me being an idiot here....
ps - can't belive no-one on here suggested it years ago!
mikexgough
Re: Amazing Heater Motor Fix!
Post by mikexgough » Sat Aug 14, 2010 8:54 pm
Pictorial here ....... ignore some of the Japanese translation...... :lol:
http://translate.googleusercontent.com/ ... a_DXylbqfw
Post by missfixit70 » Sat Aug 14, 2010 8:56 pm
Common issue, loads of discussions on that very thing, bet it smells better too :wink:
simon_gone_surfing
Post by simon_gone_surfing » Sat Aug 14, 2010 9:07 pm
How did I not know about this?! Loving the google translation! Feel something of an idiot now... #-o
Post by missfixit70 » Sat Aug 14, 2010 9:13 pm
Hope the idiot doesn't mind his "something" being felt :wink:
brorabongo
Post by brorabongo » Mon Aug 16, 2010 6:55 pm
I'll be removing that rad in mine when next under the bonnet, as the rest of the air-con has been moved anyway. The only problem....could insects now be blown directly into cab?
ボンゴの激怒 pictures
Post by missfixit70 » Mon Aug 16, 2010 7:06 pm
Potentially I guess if you aren't directing it through the heater matrix then stuff could get though, but it's still got to get through the fan & the ducting, so it's not exactly a direct route, you could put a bit of mesh over the intake?
jaylee
Post by jaylee » Mon Aug 16, 2010 8:21 pm
Hey guys...! lets not forget this little gem a while back!! http://www.igmaynard.co.uk/bongo/forum/ ... 16&start=0 :D
brorabongo
Post by brorabongo » Sat Sep 11, 2010 6:40 pm
brorabongo wrote:I'll be removing that rad in mine when next under the bonnet, as the rest of the air-con has been moved anyway. The only problem....could insects now be blown directly into cab?
Been under bonnet sooner than expected, tried to refurb the heater fan motor again...but no luck. :(
I've removed the element for the front air con. Even with a dodgy fan more air is coming from the vents now. :D
Is it likely anyone would need to replace such an item? i.e. should I keep hold of it?
ボンゴの激怒 pictures
Post by Doone » Sun Sep 12, 2010 3:00 pm
Yes keep hold of it, they can get damaged from stones flying through the gaps in the bumper etc. On our 'around tuit' list, we are going to put fine mesh behind the gaps, to prevent this from happening... either chrome type, or colour coded mesh of course. :wink:
brorabongo
Post by brorabongo » Sun Sep 12, 2010 4:56 pm
Doone wrote:Yes keep hold of it, they can get damaged from stones flying through the gaps in the bumper etc. On our 'around tuit' list, we are going to put fine mesh behind the gaps, to prevent this from happening... either chrome type, or colour coded mesh of course. :wink:
This is the little rad inside the ducting bolted to the bulk head, not the rad in front of cooling rad. That rad was disposed off a while back. Made a difference to the cooling rad. :D
You could see on the old cooling rad where the air con rad was placed, due to lack of dents in that area.
I'll keep hold of it for now. Wrong section but if anyone wants it, it's yours for the cost of postage. It's heavier that it looks mind!!!
ボンゴの激怒 pictures
wormey
Post by wormey » Sun Sep 12, 2010 7:35 pm
Didn't know this, will have a look at mine, :shock:
Daz and debs
helen&tony
Post by helen&tony » Mon Sep 13, 2010 4:11 am
Lorna
Glad you mentioned that...It is one of my "jobs to do"...builder's mesh is quite strong...except it's not available here...I think i'll have to get one of the local grandmothers to knit some wire mesh... :lol: :lol: :lol: :lol: :lol: ,,, or cut up an old chain mail overcoat (still fashionable in these parts) :lol: :lol: :lol:
Post by Doone » Mon Sep 13, 2010 12:29 pm
Oops! That'll teach me to look at pics/read the whole thread more carefully. :lol:
In the UK, our grannies only knit Shreddies which would be no use at all. :lol:
