v reg flashing glow plug (New Shape)
Greg B
Post by Greg B » Wed Sep 01, 2010 9:23 pm
I have recently become the owner of our second bongo (bought from JAL in spring). (Last one got driven into one night – while parked!)
The new one is a v reg – new shape. It is out of warranty.
Recently the glow plug has started flashing – a steady rhythmic on off on off but only once warmed up.
How do I go about sorting this problem? The diagnostic sheet says I need to know if it is pre or post 1999. Is there a way to tell the age exactly as this one seems on the cusp? Or are all new shape Bongos post Sept 1999?
I have read many posts while list so many possible problems. I’d like to be able to tell my local garage man where to start. (Cos I have no clue about fixing engines!)
Thanks for any advice.
Greg B
Re: v reg flashing glow plug (New Shape)
Post by g8dhe » Wed Sep 01, 2010 9:49 pm
You can get the exact date and details by using the VIN number see this thread http://www.igmaynard.co.uk/bongo/forum/ ... 5&p=384788
Oh and welcome to the forum!
mister munkey
Post by mister munkey » Wed Sep 01, 2010 9:58 pm
Hi Greg.
The answer is out there somewhere. There was a thread a couple of years ago from Ron Miel who found a link to the Russian Bongo peeps with a database that if you stick your VIN in, it tells you the actual date it rolled off the production line & what spec it came with at the time.
I've had a good half hour searching & cant find the link but someone a bit more savvy than me may be able to find it . . . . .
[-o<
Edit: Cheers Geoff!! :lol: :lol:
flossie
Post by flossie » Wed Sep 01, 2010 10:34 pm
Mine is June 99 I believe on a T plate and is the new shape ... petrol though ... ( assume petrol ones don't have glow plugs :D )
Liz
'99 V6 White over Silver - as yet unconverted but I may be converted!
321Away
Post by 321Away » Thu Sep 02, 2010 11:54 am
do you notice a loss of power when the flashing starts? on that age its usually the wastgate actuator/EGR controller valve, why dont you bridge the diagnositcs port and it will tell you what the problem is, irelevant of the year.
Julian
Greg B
Post by Greg B » Thu Sep 02, 2010 12:23 pm
Thanks for all the prompt advice and links - this group is great
I will try to find out the exact year via this route
Thanks Julian for this. Yes power dies away - (limp mode?) and climbing hills is a challenge when laden
Think this can be done somewhere in the passenger footwell. (But I thought diagnostics were different depending on year)
Not sure I will try myself though. I will get my garage to have a look. It goes in on Thursday.
Thanks again
Greg
321Away
Post by 321Away » Thu Sep 02, 2010 12:31 pm
have a look at this page;
http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm, tell the garage to bridge pins C and E and that will put it into engine diagnostics mode, if they cant read the code, tell them to give me a call and i'll talk them through it.
Julian
