Hi all
just putting in a secondary battery. What is the best place to earth it, anywhere on the chassis ok? Battery is placed in usual location in front of the coolant tank, there is a threaded hole right next to it in the wing, just connect the earth lead to that?
K
Leisure battery earth
eoptio
Re: Leisure battery earth
Wing will be fine - just make sure that there is a good, clean connection
eoptio
ok thanks. To wire up the internal lights etc, just run a fused cable from the additional battery postive to the fusebox and patch in there? Am asking as there is 'permanant 12v live output' on the split charge relay I got, what should that be used for?
K
K
1) Yeseoptio wrote:ok thanks. To wire up the internal lights etc, just run a fused cable from the additional battery postive to the fusebox and patch in there? Am asking as there is 'permanant 12v live output' on the split charge relay I got, what should that be used for?
K
2) Not sure without knowing with out knowing what split charge relay set up you have but connecting from +ve on leisure battery should see you straight.
There are some fact sheets in the members area to help with how to patch the fuse box.
Live Bongo and prosper.
eoptio
thanks, yes found the info ref the patching to the fusebox, will have a go at it trow
K
K
