slow HOLD light on/off,anything to do with vegoil running??
Had a look on the fact sheet on this matter,just wonder if there is anyway running a twin tank kit for veg oil would effect things at all.not sure if the fuel pump would mesure fuel supply and report fault?
Not had any gear change issues.
Not sure if the speed senser relates to dash speedo?sometimes 30 seems real slow!
Last week i selected the wrong grear the and i thought there was a gear box issue,i selected the s gear and it didnt seem to run the same.
The hold light went away half way through journey home.
cheers guys
cheers guys
- mister munkey
Re: slow HOLD light on/off,anything to do with vegoil runnin
Can't see the connection myself Jez. Flashing hold light is generally transmission/drivetrain related or something out of skew with the throttle position sensor . . . .
Have you had any work done on it lately that might have some effect on those bits?
Wow iam learning all the time,did the test as per fact sheet and came up as fault 12 tps throttle possition senser..
- mister munkey
This place Rocks!!
Should be a straightforward fix matey, may just need a bit of an adjustment.
any pointers on adjustment of that?
- mister munkey
Thats it iam sure ive cracked it!!...thanks
drives much better(and didnt even have preformance issues b4 )pulls through gears better with adjustment.
Remember our trips away in the summer when we got to a duel carrageway with a hill it kept changing up and down gears when put foot down and changing down when you dont want it too..then over reving the engine.leaving you only one option to back off the power and loose speed needed to climb hills
after adjustment it seems to get to 5th and stay there,and pulls like a train there after!! even when foot to floor,at 65 it would change down before when gave it a bit of welly.
100% seems to hold onto gears a bit longer now.noticed before in normal driving would skip through gears quickly,and change down quicker than it really needed when put a bit of power on,sometimes it felt like it would skip down 2 gears.
- dandywarhol
A great little tweek all the same!!
Thanks for adding it,iam sure sorted me out
- Alacrity
- Tribal Elder
5th? I wasn't aware 5 speed auto's were ever fitted to Bongo's? Or do you mean lockup?chipvan wrote: Remember our trips away in the summer when we got to a duel carrageway with a hill it kept changing up and down gears when put foot down and changing down when you dont want it too..then over reving the engine.leaving you only one option to back off the power and loose speed needed to climb hills
I am glad the TPS adjustment has sorted it but what you are writing makes no sense whatsoever to a transmission engineer.
- dandywarhol
The article I wrote was to allow the changes to happen earlier and not to kickdown when accelerating at motorway speeds
sorry forget every thing i posted,i was a bit over excited to post that i some how fixed it...and made no sence to me now ive looked at it myself!!!
now,when going along at 65 ish and put foot down,it stays in 4th
(ooops not 5th as there aint one!
) ...before it would change down when under a bit more load(when not needed).
as for other twoddle i wrote iam sorry!!
is what it now does.....dandywarhol wrote:The article I wrote was to allow the changes to happen earlier and not to kickdown when accelerating at motorway speeds
- dandywarhol
Still a bit of confusion methinks - if you put your foot down at 65 you would hope nothing changes and you stay in LOCKUP...the speed and revs should then be linear. At around 60 it might drop out of lockup and back to 4th (revs increase) then reselect lockup at a higher speed
will have another run 2mrw and report back.
I didnt know the term (kickdown) or (lock up) sorry for being thick!
- dandywarhol
s'ok - you'll be less thick when the weather warms upchipvan wrote:will have another run 2mrw and report back.
