Diesel fuel filter
Oldboybob
Diesel fuel filter
Post by Oldboybob » Tue Jan 04, 2011 4:14 pm
Hi, can anyone tell me if when replacing the fuel filter on a diesel bongo (1995) do you fill up the new filter with fresh diesel before fitting. Thanks. :D
Oldboybob
Re: Diesel fuel filter
Post by Oldboybob » Tue Jan 04, 2011 4:32 pm
P.S. I have looked at the instructions on the members area but it doesn't say there :?
321Away
Post by 321Away » Tue Jan 04, 2011 4:35 pm
You dont have to but you'll find your car will stall after 30 secs and take a bit of cranking,usually standard procedure to fill the new filter with injector cleaner so it gives them a pure dose of cleaner, if not then just put some clean diesel in.
Julian
daveblueozzie
Post by daveblueozzie » Tue Jan 04, 2011 4:52 pm
321Away wrote:You dont have to but you'll find your car will stall after 30 secs and take a bit of cranking,usually standard procedure to fill the new filter with injector cleaner so it gives them a pure dose of cleaner, if not then just put some clean diesel in.
Julian
I agree =D> =D>
Lost without my Bongo.
Oldboybob
Post by Oldboybob » Tue Jan 04, 2011 4:55 pm
Thanks fella's any particular brand of injector cleaner recommended or will any stuff do the trick? :D
daveblueozzie
Post by daveblueozzie » Tue Jan 04, 2011 5:00 pm
Oldboybob wrote:Thanks fella's any particular brand of injector cleaner recommended or will any stuff do the trick? :D
Redex, Wynns, STP. doesn't really matter they all do about the same job, just make sure you buy for diesel not petrol
Oldboybob
Post by Oldboybob » Tue Jan 04, 2011 5:11 pm
Cheers Dave will do that tomorrow :D
