bongo-babe
Post
by bongo-babe » Tue Jan 25, 2011 12:24 pm
being a super bright spark!!!!!
I was reversing out of a car park, (thankgoodness i had discovered before it was to late had an overhead height bar!) and a very overgrown civil gentleman (fat chav) was beeping at me and saying some not so pleasant english words at me, for me to only discover that i did in fact only have one break light and one reverse light working! well of course i did try to apologise but to no avail he continued to speak in said words.
My question is how many lights should be on etc when i do a light check???
MountainGoat
Post
by MountainGoat » Tue Jan 25, 2011 12:33 pm
All lights should be available to do their jobs. If you have a side light out at night or one of your brake lights is out at any time the police have a reason to stop you then put you through the mill looking for other faults.
Tony
rita
Post
by rita » Tue Jan 25, 2011 12:57 pm
bongo-babe wrote:being a super bright spark!!!!!
Hi bongo-babe,
Your reversing lights dont need to be working,some cars dont have them and some only have One.
As Tony has said the rest need to be working.
Cheers..
bongo-babe
Post
by bongo-babe » Tue Jan 25, 2011 1:18 pm
rita wrote:bongo-babe wrote:being a super bright spark!!!!!
Hi bongo-babe,
Cheers..
how do i know how many etc. i thought as there were 2 reverse lenses then there would be two reverse lights and the same with the brakes?
Post
by francophile1947 » Tue Jan 25, 2011 1:21 pm
Two brake lights (3 if you've got a rear spoiler), 2 side lights, 2 reversing lights. Mine only has a nearside reversing light, as I converted the offside one to a rear fog lamp.
bongo-babe
Post
by bongo-babe » Tue Jan 25, 2011 1:29 pm
francophile1947 wrote:Two brake lights (3 if you've got a rear spoiler), 2 side lights, 2 reversing lights. Mine only has a nearside reversing light, as I converted the offside one to a rear fog lamp.
thanks.
But these are not all working and late last year i had a prob where the tail lights fuse blew out whilst driving home in the dark. i did (god knows how) manage to change the fuses. Now my next question is being a bit of a fluffy girlie girl and have no idea what im doing and as my dad says "get a grown up to do it"! do you think i should change the fuses in the brake and reverse lights? or is it a bulb? as one reverse and one brake is still working? i am wondering if each light has its own fuses or if it is indeed the bulbs or combo of both> (sorry just read this through and now seems really complicated.
Post
by francophile1947 » Tue Jan 25, 2011 1:32 pm
Probably just the bulbs, unless any of the front lights aren't working as well - each bulb is not fused separately.
bongo-babe
Post
by bongo-babe » Tue Jan 25, 2011 1:39 pm
francophile1947 wrote:Probably just the bulbs, unless any of the front lights aren't working as well - each bulb is not fused separately.
thank you so much. do i take it to a shop like halfords to change these? if not do i buy a pack of bulbs from the garage like i did with the fuses or our they special type ones.?
my next job is to go onto a special ladies mechanics course to try to learn the bascis i think?
Post
by francophile1947 » Tue Jan 25, 2011 1:46 pm
It's an easy job to replace the rear bulbs
If you lift the tailgate, you'll see a couple of screws on each lamp - just undo these and slide the unit towards the outer edge of the car (you may need to hit it with your hand). Sorry, I can't remember if the tail and brake lights are combined bulbs or separate and, as it's pisitivly possing it down at the moment, I'm not going out to look
wonkanoby
Post
by wonkanoby » Tue Jan 25, 2011 1:47 pm
you can buy the bulbs any were a local garage should have both
open the tail gate
remove the 2 screws from the light fitting.....x head philips driver
the light unit needs to slide out wards of its 2 clips,might need a wack
dont pull it backwards just to the side or you will break something
now you can remove and replace the bulbs
you will need one for reverse light
and a combined stop and tail
Post
by Northern Bongolow » Tue Jan 25, 2011 1:49 pm
try and make it to the big bash ,then enrole on one of haydns super courses for the new bongo owner,you may learn a lot.
wonkanoby
Post
by wonkanoby » Tue Jan 25, 2011 1:52 pm
bongo-babe
Post
by bongo-babe » Tue Jan 25, 2011 1:55 pm
francophile1947 wrote:It's an easy job to replace the rear bulbs
thanks for your help.
bongo-babe
Post
by bongo-babe » Tue Jan 25, 2011 1:56 pm
wonkanoby wrote:you can buy the bulbs any were a local garage should have both
open the tail gate
bongo-babe
Post
Northern Bongolow wrote:try and make it to the big bash ,then enrole on one of haydns super courses for the new bongo owner,you may learn a lot.
think that sounds like a good idea. thankyou.
