Windscreen Washers
maxi_77
Windscreen Washers
I am having difficulty in getting the passenger side washer to work properly. I have cleared the nozzles as well as I can but I still only get a dribble out of it. Is it a push fit in the bonnet and can it just be pulled out for proper cleaning. If it is beyond help is there an easy replacement, bearing in mind we are in Portugal
White diesel Bongo
TonyBee
Re: Windscreen Washers
I found that a piece of 15mm plastic water pipe was the right diameter to press the locking clips in enough to remove the nozzle from the bonnet. Having removed the pipe connected to it first
If you need a small length rather than buying 2meters then let me know and I can send a small bit over.
Tony
Tony
TonyBee
It could be worth a try. I will measure the inside diameter of the pipe and let you know the size needed.
Tony
PS
Just measured a piece of pipe and anything with an 11mm inside diameter will do.
Tony
PS
