Fuel pump timing
Tricky Dicky
Fuel pump timing
Post by Tricky Dicky » Sat Jun 04, 2011 3:30 pm
Hi All, This is not strictly a bongo prob,just a Bongo engine problem.My Friend has fitted a 2.5 td motor from a Bongo into a Ford Ranger,however the Ranger fuel pump has a chip inside so it was fitted to the Bongo motor,problem is pump timing ,can't seem to find any info on setting up fuel pump timing.So come on all you boffins.
Thanks for any help in advance.
Rick
321Away
Re: Feul pump timing
Post by 321Away » Sat Jun 04, 2011 3:33 pm
pump timing is set by a locating key (woodruff) as you install the pump? as its directly driven from the crank?
Julian
Tricky Dicky
Re: Fuel pump timing
Post by Tricky Dicky » Sun Jun 05, 2011 4:41 pm
Thanks for that,is it possible to move the gears from crank to fuel pump,this motor has been stripped down a long way.
321Away
Post by 321Away » Tue Jun 07, 2011 3:53 pm
erm no idea! assumedly its gear driven and therefore could be offset
Julian
