Aircon temperature adjustment
bikerbob
Post by bikerbob » Tue Aug 30, 2011 9:55 pm
The low temperature of the aircon is fixed at 18C is this a factory setting or can it be adjusted to go lower as I want to be Mr 8) and this is the only way for me to be 8) :roll:
Re: Aircon temperature adjustment
Post by missfixit70 » Tue Aug 30, 2011 10:11 pm
The measured temp will go cooler, depending on the state of the ac gas charge, that just seems to be an arbitrary figure, not sure you can easily adjust the temp on the display.
bikerbob
Post by bikerbob » Wed Aug 31, 2011 7:45 am
Ok thanks, will look into getting the aircon re-gassed.
Post by Ian » Wed Aug 31, 2011 7:51 am
18 degrees is the lowest internal vehicle temperature that the automatic climate control system will adjust itself to. The temperature coming from the vents may be considerably lower.
bikerbob
Post by bikerbob » Wed Aug 31, 2011 6:59 pm
Thanks to all for their input, its really helpful to a new bongonaut.
