Aircon temperature adjustment
bikerbob
The low temperature of the aircon is fixed at 18C is this a factory setting or can it be adjusted to go lower as I want to be Mr
and this is the only way for me to be
Re: Aircon temperature adjustment
The measured temp will go cooler, depending on the state of the ac gas charge, that just seems to be an arbitrary figure, not sure you can easily adjust the temp on the display.
bikerbob
Ok thanks, will look into getting the aircon re-gassed.
18 degrees is the lowest internal vehicle temperature that the automatic climate control system will adjust itself to. The temperature coming from the vents may be considerably lower.
bikerbob
Thanks to all for their input, its really helpful to a new bongonaut.
