My fridge doesn't work
bongofever
Hello,
Just been away to a beautiful campsite in Eye called Honeypot, all was perfect except for one thing....my fridge does not work, although I only bought my van in June I have only got the fridge working once, and I didn't do anything different to normal.
I have ready the f.a.q with interest but still have no idea, all I know is that it was working and now it isn't - I can hear a whirring sound when I switch it on but definitely no chill. The fridge is made by Indel B of whom I cannot find anything about on the internet.
Any suggestions welcome
Tina
Tina
Re: My fridge doesn't work
Hi Tina,do you recognise it from these...bongofever wrote:Hello,
Tina
http://www.bukh.co.uk/marinefridge.htm
nigelgibson
- Tribal Elder
Teenmal is spot on. The website link is the one you need.
I have one of these and called the number on website for advice on how to wire it. They could not have been more helpful , and talked my sparky through the installation [ in the abscence of instructions as it was second hand].
Elite camper conversions in worksop are one of a few that fit them in their conversions. A quality fridge which you cannot hear running unless you pull it out of the unit and it uses very little power. Give them a ring i'm sure they'll sort it out.
bongofever
Thank you very much, will call them tomorrow
- dreamwarrioruk
im not sure but it may be one with a detachable compressor. The vitrigo fridge we have in ours had the option so that it makes it easier to install, on ours there were a total of two wires red and black or pos and neg so not exactly hard to wire. may be a possibility that one of the connections have come apart or maybe its degassed itself. Im only guessing here tho with that model.
mike, jo and emma
nigelgibson
- Tribal Elder
dreamwarrioruk wrote:im not sure but it may be one with a detachable compressor. The vitrigo fridge we have in ours had the option so that it makes it easier to install, on ours there were a total of two wires red and black or pos and neg so not exactly hard to wire. may be a possibility that one of the connections have come apart or maybe its degassed itself. Im only guessing here tho with that model.
There are more connectors on the IndelB - seem to recall there are at least 6 on a connector board to choose from so without instructions - not easy.
If distributors cant help an option is call a refrigeration engineer to look at it , i'm lucky i know one and he carries a lot of bits as they are common to many fridges.
- dreamwarrioruk
Ok ill get me coat. Why it needs six connections for a fridge is beyond me. Guess 12v 24v but others?
mike, jo and emma
nigelgibson
- Tribal Elder
dreamwarrioruk wrote:Ok ill get me coat. Why it needs six connections for a fridge is beyond me. Guess 12v 24v but others?
we didn't get it either !! After half an hour of head scratching we rung the dealer teenmal gave the link to. Cant for life of me remember how to do it cus my sparky wired it !
nigelgibson
- Tribal Elder
Hi Tina - just to clarify [ as my earlier post is a little unclear ] - i meant for you to call the distributor [ bukh ] that teenmal mentioned not Elite that i also referred to.
bongofever
Understood, but why don't I feel very hopeful!? I have a feeling this is not going to be cheap
nigelgibson
- Tribal Elder
You might be surprised - it may not be too bad !
IndelB is an expensive fridge but it doesn't mean it will be an expensive fix.
Just a thought [ sorry if it's an obvious one ] but you have turned the stat up to max haven't you ?
good luck !
good luck !
- missfixit70
& Battery is chucking out enough voltage to power it? some have a low voltage cut out, fans will start, but when the compressor kicks in it drags the voltage below the cut out so it trips out & then cycles the same again.
bongofever
Thought I would update you all - I now have a working fridge
My very busy brother (an electrician) kindly spared me a few of his minutes today, although I was looking after his children all day so it was the least he could do really......anyway, he thinks it was just a loose connection, all he did was check the connections and hey presto, it came straight on, but how long we will see.
I did call bukh and he was helpful so thanks again for that link too
Tina
Tina
