Cambelt Change on a V6
bongomike
Hello, has anyone done a cambelt change on a V6 how long would it take a garage to change as nobody has seen a Bongo in Sunny Queensland. Are there easy to follow guidelines on the forum???
thanks
Michael
thanks
Michael
- haydn callow
Re: Cambelt Change on a V6
I seem to remember somone saying around 5 hours by a experienced garage.....Doone will be better informed.
A few bits need to come out to get at the cambelt, plus I'm pretty sure the coolant too (don't quote me on that).
5 hours seems a tad long mind.
Get them to check your camshaft oil seals (4 of them) and the crankshaft oil seal as these are known to go hard after a while and seep oil. Only around £10 each so worth considering whilst it's apart.
I also got the thermostat, and belts changed on mine when it was apart, okay it put the cost up but not something you need to do that often.
Good luck. Discount trucks did mine and are well experienced with the V6.
Andy
Andy
I changed my own cam belt
i made my own clamps to lock the cams off and locked the fly wheel off with another homemade tool
its called improvisation
its no different from changing any other cam belt really just bigger and trickier to time up gotta take more off including the dropping the coolant as the bypass pipe needs to come off, dizzy comes off waterpump pully needs to come off, both auxillary tensioners and belts need to come off, dipstick needs to come off, all the cambelt covers etc. Its not for the faint hearted but possible DIY fasion if your handyish with a set of spanners, the manual is a must tho, I also took the scav fan out to get the bottom end timed up easier and moved the power steering resovior to get the belt tight up the driver side. I will add all my timing was to c#ck cause my hydraulic tensioner was goosed and the belt jumped a tooth on the driver side exhaust and 2 teeth on the driver side inlet
i also had a big rip in the belt, i had a very lucky escape to be honest and i'm glad the engine started to make a strange noise where i think the flap of belt that was hanging off was hiting the bottom of the crank
much longer and i fear my engine would have been dead.
My van is affectionately known as the pheonix in my house now
DAR
DAR
bongomike wrote:Hello, has anyone done a cambelt change on a V6 how long would it take a garage to change as nobody has seen a Bongo in Sunny Queensland. Are there easy to follow guidelines on the forum???
thanks
Michael
PS
I will come do it for you if you pay my flights
bongomike
Cheffy that's some serious skills mate, I have booked it in with a garage now but I have no manual to pass on info to them is there a copy of the cambelt change online anywhere do you know?cheffy34 wrote:I changed my own cam belti made my own clamps to lock the cams off and locked the fly wheel off with another homemade tool
My van is affectionately known as the pheonix in my house now![]()
DAR
Hey if they balls it up I might get you over to sort it out
cheers mate
Just checked the invoice from when I had my cambelt changed and the total time was 6 1/4 hours, which included fitting a coolant alarm and new front brake pads.
'Enjoy every sandwich'
bongomike
Thanks for the info Terry that's great
cheers
Michael
cheers
Michael
flossie
- Tribal Elder
I second thisapole wrote:Hi,
Andy
Liz
'99 V6 White over Silver - as yet unconverted but I may be converted!
bongomike wrote:Cheffy that's some serious skills mate, I have booked it in with a garage now but I have no manual to pass on info to them is there a copy of the cambelt change online anywhere do you know?cheffy34 wrote:I changed my own cam belti made my own clamps to lock the cams off and locked the fly wheel off with another homemade tool
DAR
Hey if they balls it up I might get you over to sort it out![]()
cheers mate
Not Really just a tight arsed mutha
good luch
D
There is a proceedure online somewhere for the 929 3ltr which is the same but where i do not know. but don't quote me on that
