Just noticed i have a side light out on the tailgate,how do i get the rear panel off to change it??
Also,is there 2 reverse lights and are the silver/clear areas on the tailgate just reflectors??
(i must get a manual
THANKS....
awww, and there was me getting excited at the thought that i could actually answer a question instead of asking all the timeSimon Jones wrote:I think he was refering to the sidelights that are in the reflector panel on the tailgate as opposed to the ones on the bodywork. These appeared on the 1999 onwards version.
Thanks for the help,again!!Simon Jones wrote:Not yet tried to remove that panel to access the bulbs on mine, but imagine its quite similar to removing the older style reflector panel: http://www.igmaynard.co.uk/bongo/forum/ ... =+Tailgate.
May be worth considering getting some LED replacements which should (in theory) have a longer lifespan.
As far as I can recall, there are just two sidelight bulbs and no reversing lights in the panel. I would pop out and check, but the vans just gone back into the bat cave for a rest after the run to East Sussex and back.
But now i know how the clusters come out.................8etty 8ongo wrote:awww, and there was me getting excited at the thought that i could actually answer a question instead of asking all the timeSimon Jones wrote:I think he was refering to the sidelights that are in the reflector panel on the tailgate as opposed to the ones on the bodywork. These appeared on the 1999 onwards version.![]()
Ahh right,spot on ta....i did remove the 4 plastic fixings but the panel was still tightly held,are there more panel fixings behind or is the panel glued on,i don`t want to destroy the panel when i try and pull it off.Poohbear wrote:If you remove the trim panel on the inside of the tailgate it allows you to get at the two bulb holders for the side lights
