spare wheel and towbar
Fitted a towbar on the bongo and bought a full size spare wheel (didnt have one) it doesnt seem to fit under the vehicle is this because of the towbar i didnt try the wheel before fitting the towbar! Ta
Re: spare wheel and towbar
Most do fit but a few bars get in the way, you do need to push the wheel towards the front a bit as you wind it up, ours just touches the bar mount.
- Driver+Passengers
Deflate the spare and see if that helps.
You might find that there is a small location bracket on the underside in front of the spare wheel. I had to bend this get our spare in after fitting the tow bar.
cheers lads will check out that bracket.
