spare wheel and towbar
bigboy
Post by bigboy » Thu Oct 18, 2012 2:18 pm
Fitted a towbar on the bongo and bought a full size spare wheel (didnt have one) it doesnt seem to fit under the vehicle is this because of the towbar i didnt try the wheel before fitting the towbar! Ta
Re: spare wheel and towbar
Post by g8dhe » Thu Oct 18, 2012 3:29 pm
Most do fit but a few bars get in the way, you do need to push the wheel towards the front a bit as you wind it up, ours just touches the bar mount.
Driver+Passengers
Post by Driver+Passengers » Thu Oct 18, 2012 3:36 pm
Deflate the spare and see if that helps. :roll:
Image Image
briwy
Post by briwy » Thu Oct 18, 2012 5:03 pm
You might find that there is a small location bracket on the underside in front of the spare wheel. I had to bend this get our spare in after fitting the tow bar.
bigboy
Post by bigboy » Fri Oct 19, 2012 7:15 am
cheers lads will check out that bracket. =D>
