are they the same as the diesel rockers ones simon, do they have a soft steel tube insert that spaces them from the head face.
if yes they stop you crushing the gasket, but if tightened more than allowed it causes the tube to crush and distort.
the way i got round this was to remove them all and grind off one mm of each tube, this allows the cam cover to sit lower and seal the gasket better and re seats the top rubber seal tighter.
even works with an old age hardened gasket on the diesel.
http://lushprojects.com/bongopartsmk2/c ... o=.html#14
