Battery light
Battery light
Another little niggle appeared today on Bobby. Took him out and noticed the battery/charge light stayed on. Never had this before. The symptoms are that if I accelerate the light dims but does not disappear completely. If going down a hill the light glows brighter when I let my foot off the accelerator. All the electrics are working fine and it started fine this morning.
Any ideas?
Any ideas?
I can, I do, I did.
- mikeWalsall
Re: Battery light
Check your alternator belt is tight ... but when that happened on my V6 .. the light would go off at over 2000rpm .. and come back on at at lower revs ..
Turned out to be the diode pack on the alternator .. rather than a new alternator a local place fixed it for me ..
Re: Battery light
Dont know why but cant get this link to open on either my iPad or laptop!!!
I can, I do, I did.
Re: Battery light
Works on my iPad
Try clearing history
Go into safari then clear search history
Re: Battery light
its the first topic in this section
just below announcements
- mikeWalsall
Re: Battery light
On my desk top .... viewtopic.php?f=3&t=68907 .... is not a link to anywhere ..
It is this topic ..
It is this topic ..
Re: Battery light
The charge lamp staying on indicates that the alternator is not generating power ..... either the belt or faulty alternator in some way.
Re: Battery light
Yes just takes me back to top
Didn't read it earlier
Re: Battery light
This is probably the link that was intended: http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=51027
Re: Battery light
OK. As it has decided to stop raining on the Mendips today I went out and had a play with the alternator. I thought the belts were a bit slack so adjusted the tension. Started him up. Light stayed on!
How and what do I test on the alternator to find out if it's faulty? I'm not very good with electrics so please the answers simple!!!
I can, I do, I did.
Re: Battery light
Right. Had a look at the link. Very helpful, however I think I've resigned myself to the fact the alternator is knackered. There is a company not far from me who repairs them. Before I give him a call, what make alternators are on the Bongos? Lucas, Bosch......? Or is it some Japanese make no ones ever heard of? He's bound to ask when I phone him!!
I can, I do, I did.
Re: Battery light
Depends on year and engine type, the fixings and style varies!
This company are quite good, but getting it refurbished locally is probably cheaper!
Put Bongo in the search box and it will show you all the types as well as starters...
http://www.startermotor-alternator-stor ... ion=search
