Squeak from rear wheel when reversing and turning
TheStinkyHippy
Post by TheStinkyHippy » Fri Sep 18, 2015 10:09 am
When I reverse off the drive and turn, there is a squeak from the driver side rear wheel area.
Difficult to know where exactly as i'm behind the wheel and the engine is being noisy, and lots of beeping going on.
What should I look for/at?
2.5TD 4WD N-reg
wonkanoby
Re: Squeak from rear wheel when reversing and turning
Post by wonkanoby » Fri Sep 18, 2015 11:21 am
might be related to shoes in drum brake
Post by mikeonb4c » Fri Sep 18, 2015 12:16 pm
TheStinkyHippy wrote:When I reverse off the drive and turn, there is a squeak from the driver side rear wheel area.
2.5TD 4WD N-reg
No possibility it could be linked to the constant velocity joints, given yours is 4WD? I've read that the first symptom is a noise when turning hard at low speed, though I don't think its a squeak as much as a clicking, and not especially when reversing. But still, something to put alongside brakes as a possible?
ELZE
Post by ELZE » Fri Sep 18, 2015 1:56 pm
I have the same type of problem on my V6, a kind of groaning like brake shoes hanging on in reverse only? Maybe its all the mud of the site roads I am on daily. will have to wait and see when I get back but will watch this thread with interest.
A Bongo is for life, not just for Christmas
helen&tony
Post by helen&tony » Fri Sep 18, 2015 3:50 pm
Have you checked to see if it's an LSD at the back...I get an occasional squeak on my Jeep, as it has LSD
TheStinkyHippy
Post by TheStinkyHippy » Sat Sep 19, 2015 1:19 pm
Ok. Pretty sure its not the brakes.
Jacked up the back and when hand turning nearside rear it sometimes squeaks.
Removed wheel, pads and disc, handbrake was a little sticky and it even squeaked when the drum wasn't attached..
So, next. Diff oil... never done or checked that.
That is my rear diff..
Is nut 1 the fill hole?
Is nut 2 the drain hole?
To check the level do you remove nut 1 and the level should be up to the opening?
Not sure if I have LSD or not.
When I turn the rear wheel by hand, the opposite side turns the other direction.
Thanks for help.
Tony x
Post by Tony x » Sat Sep 19, 2015 2:15 pm
LSDs are usually identified by a yellow paint splodge and, if you turn one of the rear wheels, the other turns in the same direction (so I've read)
Looks like yours is not a LSD
Post by Northern Bongolow » Sat Sep 19, 2015 8:31 pm
thats right, lsd fitted the wheel if spun hard should go the same way. fill up to the level of plug number 1.
refit the wheel for extra leverage, jack up, and try to tip the wheel bearing with a pry bar, rotate a little then try again, could be wheel bearing.
http://lushprojects.com/bongopartsmk2/c ... no=.html#9
TheStinkyHippy
Post by TheStinkyHippy » Mon Sep 21, 2015 7:33 pm
So, rear diff oil changed. The drain and fill plug were a bu**er to get off, but eventually did.
For reference the fill plug is a 23mm socket, and the drain is 24mm socket.
Refilled with around 1.6lt of SAE90 oil. (I'll do the front next weekend)
Here is what came out;
Lets see if that makes a difference.. if not I will look at the CV joints... any pointers to what they are (sorry Northern I didn't understand your post)
