Burping bongo
alze
Burping bongo
Post by alze » Thu Oct 07, 2021 9:04 am
Hi Team,
Recently had an issue with my bongo overheating, thankfully identified as a leaking pipe going over the starter motor.
Since then I have noticed that the temperature gauge will creep up, and sometimes go near to high, then go back down to near-normal at the C end of the meter. The bongo makes some 'gurgling' noise which I think is air being released.
I know that they refilled the coolant as I had put standard tap water as an emergency in previously, do you think its not been bled properly, or is it something else ??
Kind Regards,
Al.ze
Re: Burping bongo
Post by Ian » Thu Oct 07, 2021 9:08 am
Sounds like an airlock in the system. It needs bleeding again. See the "Bleeding Bongos" video on YouTube
alze
Re: Burping bongo
Post by alze » Thu Oct 07, 2021 9:11 am
Wow - thanks for the quick reply Ian - hope you are keeping well, and thanks for keeping the site alive :)
Re: Burping bongo
Post by g8dhe » Thu Oct 07, 2021 10:54 am
Which engine type do you have ?
If its diesel then make sure it gets bled well, V6 is not quite so bad and the 2l is self bleeding but even so it needs the worst of the air to be removed before topping it up adequately!
alze
Re: Burping bongo
Post by alze » Thu Oct 07, 2021 10:59 am
Hi Geoff,
Apologies, yes i should of included that !
Mine is a diesel.
I notice your callsign - G8DHE - hello from 2E0FWE.
I am hoping for fair weather this evening so i can follow the bleeding process.
Kind Regards / 73
Alan / 2E0FWE
Re: Burping bongo
Post by g8dhe » Thu Oct 07, 2021 11:04 am
Hi Alan, often down Poole way my son (2E1GHZ) is down there, do have 2m and 70cms in the van but not very active these days.
alze
Re: Burping bongo
Post by alze » Thu Oct 07, 2021 11:54 am
My 2M/70cm mast is not up at the moment (40ft) in IO90BS, but I'm usually monitoring. Tend to use the GB3IW repeater with its fantastic south coast coverage, and Mere when IW gets too busy !
To keep to Bongo-thread friendly I do enjoy very much going to the New Forest in the Bongo with my radio(s). Not got a perm one in the Bongo yet, thinking to put a 10M / 11 switchable one in there - have had 11m radio in there before was good fun on one of the previous commutes I had between Bournemouth and Romsey - plenty of activity.
Will be lovely to meet or have a QSO - your baloon work looks very exciting !!
Thanks again for the advice on the Bongo - i missed it so much for the week it was in the garage, it really is well loved by me and my good lady (XYL).
A.
Re: Burping bongo
Post by g8dhe » Thu Oct 07, 2021 1:22 pm
Yup the HAB activities are quite fun, although they have slowed down quite a bit in the UK for the last couple of years!
Nearly first thing I did was re-install the radio in the new vehicle IC-2800H,
alze
Re: Burping bongo
Post by alze » Thu Oct 07, 2021 8:53 pm
Hi All,
Pleased to reporting that following the video resulted in the temp staying rock-solid on Low, appreciate all the videos and input on here.
And nice to meet a fellow amateur radio operator - hopefully our bongos and log-books will be in touch some day.
Kind Regards,
Alan
Re: Burping bongo
Post by Bob » Thu Oct 07, 2021 9:25 pm
Well done. 8)
G0RMH, not been active for a good while.
Re: Burping bongo
Post by g8dhe » Thu Oct 07, 2021 9:56 pm
I didn't realise you were licensed Bob! You kept the quiet!
Re: Burping bongo
Post by Bob » Thu Oct 07, 2021 9:59 pm
Yep. 8)
Re: Burping bongo
Post by Northern Bongolow » Thu Oct 07, 2021 10:02 pm
No Geoff you misunderstand, he's out on license.😉
Re: Burping bongo
Post by Bob » Thu Oct 07, 2021 10:10 pm
Northern Bongolow wrote: Thu Oct 07, 2021 10:02 pm No Geoff you misunderstand, he's out on license.😉
:lol: :lol: :lol: :lol: :lol: :lol:
alze
Re: Burping bongo
Post by alze » Fri Oct 08, 2021 4:48 am
Funny thread now :)
I dont have a perm setup in my Bongo yet for a radio. Will investigate over the winter.
Here is the video of operation from the New Forest from the Bongo !
Was great fun to get away from the interference of the home.
https://youtu.be/MKd5ZWDUz-E
I'll have to search the forum for any tips on setting up a radio in a bongo for grounding - i was going to try a plate to the roof but decided against that in the end. Have tried a gutter mount with some sucssess, but was only measuring S.W.R. readings - whats the capacitance and resonance of a mazda bongo hahah :D
I'd be interested in swapping out the antenna on the side with a 2m/70 type of whip - any of my fellow hams done that ?
